Wyze app for IOS Nag screen for Microphone Permission
The Wyze app constantly asks for Microphone permission every time it’s opened. Yes or Cancel is not a good option. Yes or No would be much better, and perhaps the nag screen would not open every time the app does if NO was a response. Please fix this! Thank you.
That sounds like a bug, all right. Best place to report those for good visibility by the Devs is in the announcement thread of the app version you are using.
In the meantime, you might want to try this as a workaround: Accept the microphone access, then go into system settings and turn it off for the app. Maybe accepting it will set the bit to keep from asking the question again, and your microphone access will still be off.
Good luck! :slight_smile:
The microphone permission request only happens once a day, so it’s on some daily clock. I can accept it, but it only goes to the permissions screen in IOS, and accepting it then turning it back off does not stop the nag screen from appearing the next day.
I have no idea how to find the IOS announcement thread. It does not appear in any of the drop down screens to post this topic.
Typically, to find an announcement thread on software of firmware you just search for the version number. Because of some thing they do on Facebook, sometimes they forget and put a space before the last set of numbers. But knowing that, you still have a good shot at finding it. Announcements are usually also high in the News group, or even pinned at the top. You can find the News group in the Forum drop-down. All groups are also available if you just click on the word Forum above that drop-down.
The version number of the app is under the Account tab > About (under the Wyze logo), and the version number of any firmware you want to talk about is in Device Info for each device.
You don’t need to worry about reposting this though, as others have already noticed the same bug and have reported it! :slight_smile:
Thank you so much for your reply. I will look for App topics by searching the app version from now on. I appreciate your kindness!
