I wanted to use my android tablet to view multiple (4) cams on the same screen as once using group in landscape mode but it doesn’t works.
On my android phone and iPad when I turned it to landscape the app will rotate and display 2x2, 4 cams at the same time. If you have more cams you can swipe it to display 4 more cams.
But on the android tablet the app still displays in portrait mode and the cams displays vertically. The most I can see is 1 full cam and portion of the 2nd cam. Auto rotate and smart rotate already enable but none works like on the phone or the iPad.
What am I missing, doing wrong? The tablet I used is the Lenovo m10 plus 3rd gen.
Anyone having the same issue on their android tab?
Added:
The tablet running android 12 after upgraded to 13 still face the same problems
