WYZE Android app and Smart Sony TV
My old TV finally died so I now have a new SONY Brarvia TV. It says it is an Android TV and has Google Play on it. Can I just add the WYZE app and use the app to view my cams or do I need to add another program/app. ???
I don’t have any experience with Android TV appsM but I would think Wyze or TinyCam would work if they’re available in the TV’s Play Store.
Let me know if and how it works!
If it has Google Play you may be able to just add the Wyze app. If you add TinyCam, you may also need special Wyze RTSP firmware.
WYZE app not available to use on this device is the message I got.
Unfortunately, it must not be available. Have you tried TinyCam?
TinyCam connects directly to your Wyze cameras using P2P.
This article shows how to set it up:
https://iotrant.com/2018/04/02/use-tinycam-monitor-with-your-wyzecam/
Thanks for the information, maybe I will give it a try in the future. It’s not an important issue right now, just thought I would give it a try to see if it worked. I only have 5 cams and use my iPhone most of the time to keep track of what is going on.
There’s a decent chance you will be able to sideload the Wyze app, if the TV can enable installation from unknown sources.
