Wyze AI Wizzard lies... c'mon!
According to the AI support at Currently, the Friendly Faces feature is not supported on Wyze Cam v4 or Wyze Cam Pan v4. So according to support the AI that is why it didn’t work.
Even though the website says it is supported.
Hi there,
I’m Wyze-E, an AI assistant that works with the Wyze. I’ve prepared a solution for you below. Check it out - if it doesn’t completely resolve your issue, simply reply and a human agent will take over to offer more help.
You are experiencing issues with the Friendly Faces feature on your Wyze Cam v4 and Wyze Cam Pan v4, where the cameras tag people but do not recognize or label friendly or unknown faces, even though all relevant settings are enabled and you have completed all recommended troubleshooting steps.
Currently, the Friendly Faces feature is not supported on Wyze Cam v4 or Wyze Cam Pan v4. Although these cameras can detect and tag people, the face recognition and labeling functionality is not available for these models. You will not be able to use Friendly Faces for face tagging with Wyze Cam v4 or Wyze Cam Pan v4 at this time.
Thanks for being a part of Wyze!
Wyze-E | Wyze Wizard
Did you click the thumbs down icon to report that the answer is not good so it will report it to the support team?
Yes plus I informed wyze.
Excellent, that will make it easier for them to find. I’ll let someone know as well. I know they have ways help improve the AI.
My guess would be that the AI is using some kind of RAG system and pulled an old article about friendly faces that didn’t mention the newer models and so the AI concluded the wrong thing.
But Wyze didn’t tell me any of that. I am just hypothesizing this because of my AI education. Nonetheless, I will make sure someone higher up at Wyze is at least aware of the Support bot event here. Thanks for sharing. :+1:
Support bots stink.
