Can’t get text message notification never received from time it was new only had for 3weeks tried everything still no text could watch be defective
Welcome to the community @larryok
Make sure you have allowed Nearby Devices on the app, this is required form BT devices now. It is an Android thing.
Also, here is a link of things to check as provided by @towelkingdom
where do i find the option for nearby devices on the app
Should be in your phones settings, under privacy or permissions or something
i can not find that option under phone settings… i looked everywhere my phone is a oneplus nord N10 5g
Sorry, been out of pocket for a bit…
Long press on the App Icon and select App Info. Then Select Permissions, under there you should see a Nearby Devices selection. Permit that.
Are you running Adroid 12?
i am running version android 11 and i dont see anything for the app Nearby Devices i looked at all the options under permissions
So Android 11 does not have it there, I believe. Did you go through the steps via the link I provided? I believe on Android 11, there is the Special Notification area you need to allow as well
Yes I did that there were 2 wyze and I allowed on both
could it be a defective watch i just got it less then month and the text never worked
Could be. Have you contacted Wyze?
Yes I have a log id number from them should I have them send me a new one return this one
i solved the problem of not getting my text messages… i downloaded google message and made that my default for text messages and i am now getting my text on watch… for some reason the message app that came with android phone does not work with Wyze… problem solved
