Wyze 180 degrees
As an idea, I would like to propose that Wyze developed a camera that has he cameras , one in the front, one to the left and one to the right. You could call it Wyze 180. This is helpful when using Wyze outdoor and is able to capture all around incase someone tries to steal the camera from the side or just avoiding been recorded.
Have you seen Duo Cam Pan? That already combines two cameras into a single device to give >180° of horizontal coverage. Since you tagged your topic with cam-og, you might want to note that you can already use the Stack Kit to join two of those and provide >180° of horizontal coverage when you combine the FOV of each, as well.
If some of your Wyze cameras are outside and theft is a concern, you might try mounting additional Wyze cameras inside windows (to watch for outside cameras being stolen). All of my Cam v3 cameras are inside looking out windows.
I also use multiple v3 cameras which gives me a wider view of my front street.
The upper right picture is the view that the camera in the first picture sees.
