Wireless Outdoor Camera V2 questions (was Cam OG and Wyze View)
This OG camera is going back to Home Depot this morning. Unfortunately I don’t currently have time for extended troubleshooting.
So now I’m looking for a replacement, and I’m considering the Wireless Outdoor Camera V2, the one that comes with separate cameras and base station.
Three questions…
  1. Reviews on the Home Depot website aren’t exactly universally favorable (gets 3 stars out of 5). For those of you who have this camera, how well has it been working out?
  2. I see the camera is battery powered and needs to be recharged every couple of months like the doorbell camera. How has that worked out for you?
  3. I see that the camera is NOT compatible with Wyze Web View (seriously???). Does that mean it’s also not useable in Groups? That would be a show stopper.
Thanks…
Thanks, @Rulwiz, for your extensive and detailed reply.
Regarding groups, if the camera would run down the battery quickly if viewed with Web View, wouldn’t it also run down quickly when continuously monitoring the camera as part of a group?
Incidentally, not all of the battery cameras can be used in groups. The Doorbell Pro is one that can not, perhaps for the same reason.
I suppose I should re-think this issue of wired vs wireless. So far the OG may be out because it appears to be unreliable (at least, this one was), and the WOC V2 perhaps may have battery issues if continuously monitored. So what are the alternatives? Maybe the Wyze Cam V3?
I don’t have on, but my opinion is that the battery powered cameras are so restrictive in capabilities in order to save battery life that they are almost useless. You could not give me one…
That was a very good explanation of the WCO @Rulwiz :clap:
Adding on, I agree that if you have access to power you should definitely use a wired cam. The battery cams are lacking a lot of features to allow for the battery to last.
What issues did you have with the OG cam? If that cam was unreliable then it could be a network issues instead. The OG is significantly faster than any other cam.
It freezes up and requires cycling power to get it back. Then it will run OK for a short time and then freeze up again.
I tried putting it right next to my wireless router and verified that it gets maximum bars. Internet connection here is more than 25 MBps down and 10 MBps up. No joy… it runs for a short time and then freezes up.
When you say freezes up, do you mean the live feed stops and your not able to get it to start again, or does it say the camera is offline?
Live feed stops and I can’t get it going again without cycling power.
What if you back out of the live stream and back in, does it get stuck on loading or what happens?
It gets stuck on loading until I cycle power. Unfortunately I can’t give you the exact indication. Normally I would be happy, even eager, to spend some time troubleshooting this thing but in this instance I had to return it to the store and exchange for the indoor-outdoor cam V3 which I’m testing now.
That’s an interesting issue. Let us know how the v3 works for you. The OG could have been faulty or just not playing well with your specific setup, so hopefully the v3 works for you.
I’d say the former is more likely than the latter; my setup is pretty plain-vanilla and my two Cam-Floodights and my Doorbell Pro (and now my V3) seem happy.
Great thing about Home Depot… they’re like 2 miles from me, have a good stock of this stuff, and they take returns with no questions asked other than “Is it defective?” in which case they’ll put a Return To Vendor sticker on it so it doesn’t end up back on the sales floor. Picked up an Indoor-Outdoor V3 and so far it’s been solid after about 20 hours, we’ll see if that happy situation continues.
