Would love a wifi 7 mesh system
@elchawii , Please make sure you vote for your wish as the system does not add a vote for you
I was first vote. Do I get a free mesh? ![]()
No idea how to use wyze forum.
Anyway, hopefully no [Mod Edit] moderators to be like you need to take this someplace else…
I like simplicity.
Some places in a home just need a little bit better signal and mesh networks can help at the expense of eye pollution…
Why not integrate into a wall outlet a wifi mesh relay?
Power, check
Everywhere check
Installation difficulty depends on experience
No more mesh towers priceless
Congratulations! You figured it out and didn’t offend the moderators.
I have the Wyze Mesh Pro system and am super happy with it… BUT a wifi 7 mesh system would be better … Just my 2 cents
Do you have anything that connects to Wifi 7? My brandnew phone will connect to Wifi 6 only.
Future proofing is good.
Short answer Yes i Do …
At work we have upgraded to Unifi Wifi 7 and have been upgrading all of our devices to support the faster speed…
We even got a 5gb synchronous connection at all of our offices … makes transferring large files real nice
Most new phones support Wifi 6E and 7 unless you got a new Old phone…
Wow. I have the newest S24, guess I should have held out for a S25. If I waited Wifi 8 might come out. I could see connecting to a Wifi 7 router but actually using the true Wifi 7?
I still doubt that most new phones support Wifi 7 in the USA or Canada.
Glad you are Wifi 7 fortunate.
I have WiFi 6E (Wyze Pro mesh) at home and the only things using it are my phone and laptop(s). That really amounts to 4 devices out of 60 that connect. I think the overall benefit of these newer routers are processing, RAM, and bandwidth optimization.
I’m not convinced that the 6E band is alleviating any congestion. I’m sure it helps the non-wired Mesh AP that uses that band to communicate to the primary node. I’m going to wire those together soon anyway so all the nodes are hard-wired.
