What is the use case for Climate Sensors
What is the use case for the Climate Sensor? Can it direct more or less AC or heat to an area? Is it basically for information purposes only?
Informational, or use it with home monitoring to be notified when temps or humidity goes over or under certain thresholds, also can be used with automations as triggers. Temp gets to hot, turn a bulb red, temp gets to cold, turn a bulb blue for example.
I use them just as info, have a few placed around the house to see the differences upstairs, downstairs.
I use them to monitor seasonal properties. I keep track of Humidity / temp and can adjust HVAC systems remotely to adjust both.
Perfect! Thank you.
Thank you,
Kurk Erickson
Here’s my use case…
Woke up to my freezer wide open… Ice is water, meat is soft.
The cat jumps on the fridge to get to the to of the cabinets. There was stuff in the way so he kicked the fridge open. My cameras caught it (thank you Wyze).
It’s now monitoring my freezer from the inside. Temperature gets down to be 4 and hovers at 12. F.
Really! That’s interesting and I’m going to guess not common to use in freezer. I like it though and we’ve lost more than one freezer full ourselves. Thanks.
