Water resistance of V4 pan -?
I’m wanting to mount some V4 pans outside. The optimum mounting would have them almost horizontal with the vent holes up.
Location is northeast Virginia, so I expect a lot of rain.
What is the chance they will survive?
All models of Wyze cams use inferior lens that the adhesive eventually breaks down then moisture makes its way in and they get the lens fog.
Ever since V3’s came out they started using the cheaper lens assembly.
I wouldn’t recommend anything but upright unless you put a cover directly over it. That’s how it is with my Panv3s (had one upside down under an eave and got water in it), I’m guessing the Panv4 is in the same boat.
