My watch just updated to 0.12.49 but I’m not finding anything on the forum that tells me what’s in the update. Anybody know? Or can point me to a source? Thanks.
Wyze Watch 47mm :
Version: 0.12.49
What’s New:
- Turned off continuous heart rate measurement by default
- Optimized ANC connection
- Solved the abnormal connection problem from version 0.12.48 that caused issues such as watch face syncing failure
you are too fast. ![]()
I was getting the info came back and you had it.
Hmmm, I just checked for an update - my Firmware Version is 0.12.43 and reports "it’s up to date: ???
Thanks @Newshound . Much appreciated!
@mstricklett . Are you in the beta program? This is a beta release.
No, thanks for the heads up!
I can’t even update to 0.12.49. I’ve tried restarting the watch, and everything, but it just fails every time. Farthest I’ve made it is 17% then just restarts, and eventually fails. Not sure what to do
