As has been already said, create a group. Any cameras in the group will be displayed when you open the group. WCOs will show a play icon, they do not automatically play. My V2 automatically plays.
Well…I might be out of luck with travel mode. It requires me to connect to the camera’s WiFi and each camera in travel mode has it’s own WiFi channel. Can’t watch them together in a group.
Would have to disconnect from one and start the other.
you may be able to do something like this: LifeHackster. I subscribe to this channel as he has some interesting takes on things. the link provides a method of potentially doing what you are looking for, but will require for you to purchase 1 more item.
Have you tried doing travel mode from the base station, not just the wco itself? I haven’t myself, but that may help you connect to multiple at once. Scroll to the bottom half of this page:
Inverters are cheap. Just don’t let it run too long without the motor running. A little math will give you an idea how long is safe. I suppose you could also just feed it 12 volts DC straight with a little cabling work and optionally a second battery pack. Here’s what the site shows as the power input.
Were you ever able to get this going? I’m struggling to view more than one cam on travel mode.
Able to connect the base to travel mode but can’t connect any camera to the base when it’s in travel mode. What’s the point of the base being in travel mode?
Able to connect 1 cam to travel mode, but since each cam broadcasts its own wifi, can’t connect multiple.
I had a very similar use case to you. Bought the Wyze outdoor to satisfy the purpose with its broadcasting wifi signal, but seems like a major flaw that you can’t view more cameras simultaneously.
