Video length with q 32 GB SD card
Is there a way to extend the video length longer than 12 seconds with the 32 MB SD card installed?
As far as I can tell, you can turn on the feature to record 24/7 on your SD card but at HD, it can record only 2 days worth of video before it starts to write over the old stuff if that makes and sense. The 12 seconds is the limit for their free cloud upload feature.
Welcome to the forums! You mentioned two ways of recording that are Independant of each other.
  1. Cloud recording, the 12 second clips. These are saved to the cloud weither you have an SD card or not. These are mainly for notification purposes. You can record for longer but you need to subscribe to CMC, visit the wyze website for more on that.
https://support.wyzecam.com/hc/en-us/articles/360031134652-How-does-cloud-recording-work-
  1. SD card recording. Are you sure you have a 32 mb card? Is it a 32 gig card? Making sure because you mentioned mb twice. This is independent of cloud recording where you can record continuously or event only to the SD card in your camera.
32 GB, sorry
another option if you happen to have a whopping 1.49$ a month for each camera would be the Wyze complete motion capture. this is cloud based though. it also removes the cooldown period for any cameras you have this on.
read about it HERE
