Video Doorbell v2 Jump to SD is buggy almost always fails
When I click on a motion event in the app from either the general events feed or the doorbell’s feed itself, it briefly shows the event (for a second) and then, without doing anything else, jumps to about 7am (regardless of the event time). It makes using the SD card to look at events pretty useless because I have to manually find the event.
Can this please be fixed in the next app release?
Thanks!
I suggest posting this in the Fix-it-Friday event thread tomorrow. That has the highest chance of getting a lot of recognition for it. If it is also the highest liked issue by the community it will also get weekly updates/reports on the progress for it (it will get attention either way, but it’s nice to get official progress reports).
This bug presents on my newly installed Doorbell v2. Quick app work around: (from Home screen Doorbell device open) after doorbell recent event glitches to time in past on ‘Jump 2 SD’, tap live view button, then tap desired event/Jump 2 SD…my app then plays the correct time frame. Wyze needs to fix this.
