Having trouble getting power to Wyze Video Doorbell. Not sure how to connect direct to the transformer? Transformer is 16V, 10VA. Is this sufficient?
mine is the same voltage, works fine. What happens when u wire the doorbell to the transformer?
I do not have a doorbell transformer can I wire the button directly to a 12 volt power supply?
It works connected direct to transformer. I don’t know where to put the fuse now?
you can install it on either wire, doesn’t matter
Cool all working now. Thanks y’all.
