Add me to the list. Similar to OP, initial setup was fine, connected to wifi no issues, updated firmware to .233. At some point over the next few days, the endless reboot started. I wish I knew a more firm reboot start time.
Attempts to ‘factory reset’ and setup the device many many many times would never stop the reboots, or allow any sort of access access via mobile app or get the chime to connect to the device.
Things I tried:
~ Using different wifi SSID network
~ Power cycling (many many times)
~ Powering up, factory reset, setup near my wifi access point
~ Installed ‘new’ doorbell transformer
~ Confirmed correct voltage at door, doorbell, and even powered it right off the transformer thinking maybe my wiring was bad.
~ Powering up while holding reset button
~ Many different combinations of reset button holding during power on, after power on, removing power during factory reset button press… etc
~ A bunch of stuff on the android app side. Deleted device from account, cleared cache, cleared storage, fully removed app, created new wyze account, tried adding failed unit to totally fresh app install with new Wyze account.
No success.
Interesting things during my testing:
~ 9v DC battery seems to be enough power to boot (though still endless reboots)
~ During setup on a failed unit, the “setup complete” phrase is ‘cut short’ (setup comp…) followed by a quiet steady ‘static’ sound that emits until the device reboots about 60seconds later.
~ During boot sequence, pressing the doorbell button will emit a ding-dong from the device… UNTIL, the steady blue light appears when the button doesn’t work and the quiet static sound appears. (software hung?)
~ While I could never get access via the mobile app, (it would never ‘connect’ to the device after setup and show video or allow config changes), I DID get what looks to be one initial device info populated page during/after setup, Here the wifi signal strength meter showed ‘no bars’ even next to my access point. New working unit shows full bars.
~ The device DOES connect/associate successfully to my wifi network, evidenced by my ability to PING the device’s IP address when the light is solid blue.
~ A working device has a service listening on port 10002. A failed device will only respond to ICMP pings, There’s never a listening service.
~ Activation date was accurate to my ‘first’ setup date March 9th 2021 and never changed.
~ Even in a ‘hung state’ quiet static, solid blue light, but unresponsive. I do see the device making ‘some’ internet connections to wyze related domains. And my network monitoring shows about 1MB of traffic to/from Wyze servers (various api related domains at .wyzecam.com). So SOME sort of process/service seems to be still alive/active and talking to Wyze cloud even in this ‘hung’ state.
My best guess is that the wifi hardware/software has a bug that fires right at the point it joins the wifi network (blue light goes solid). At that point the software hangs until a ‘failsafe reboot’ kicks in 60 seconds later. If it were possible to push firmware to the device during the setup phase (where your mobile app IS able to talk to the device before ‘setup complete’) I think you could recover the device.
Anyways…
Emailed and opened a support ticket, they were polite and responsive for a few days, and then ghosted me. Odd. Figure they are super busy, so I decided to replace the defective unit via ‘other methods’,
New unit works perfectly (so far). I’m going to leave it on the original firmware .202 and wait till release of firmware after .233 just in case.
I love the size and I’m still a fan of Wyze products and would not tell someone not to get one of these. I think this is more early adopter adventure. For the price, features, and size, this is pretty cool and I trust the bugs will get worked out.
fwiw
