Greetings,
I’ve been trying to setup an IFTTT applet to turn on some of my Wyze Bulbs (Color) when a Wyze Contact Sensor is opened. I can’t use a simple in-app Wyze rule because my desired condition is more complex than the time of day alone can provide, hence why I need IFTTT.
My problem is that the Wyze triggers aren’t being delivered to IFTTT nearly fast enough. I know that Wyze is receiving the Contact Sensor state changes in a few seconds, because I get notifications on my phone. I also know that the problem isn’t on IFTTT’s side, because if I use another trigger for my applet (such as an Android home screen widget), the applet triggers in a few seconds too. It’s just that when I try to use a Wyze trigger, it takes anything from minutes to hours. Please see the following screenshot, I’ve had delays between 3 minutes and 1 hour 38 minutes, both of which are unusable for smart home integration, but the latter being straight up abnormal.
The triggers that IFTTT received between 3:19 AM and 3:27 AM actually happened between 1:41 AM and 1:49 AM. Is there hope for my project, was there just a service problem when I was running my tests? Any help is appreciated, thanks in advance.
Respectfully,
Hugo
