Vacuum Stops Cleaning Too Early
Twice now, I’ve set the vacuum to clean a room and it will start, get about 4 square feet into cleaning and then announce, “All clean” where it then returns to the base station triumphant that it helped, but it didn’t. :slight_smile:
Does anyone have any tips. This seems to have occurred after I had to remap my floor recently. I did look for other topics that were similar, but didn’t see anything in a quick pass. If there are other similar posts, I’m happy to follow guidance as needed.
I had a similar issue. I added a small no-go area where it ended it’s short route and the next time I cleaned it completed the entire room. I haven’t removed the no-go area yet so I don’t know if this is a permanent fix or not.
Thanks. Based on your suggestion, I adjusted a No go zone and it is so far cleaning more. Seems weird but happy it worked.
