My vacuum successfully created map of the first floor. I know that now only one map can be created and stay in the memory. If I use vacuum in a different room the first map will be erased and new map will be created, correct? Can I save the first map (first floor map) because I don’t need a map of the other room. I want to keep the map only of the first floor in memory . Is it possible to use vacuum in different room without creating new map of this room.
Will saved map be erased (reset) if I start vacuum cleaning with a button push on a vacuum compare to start from the app?
When Wyze is planning to add an option to save several rooms to the app?
