Vacuum doesn’t recognize map
As of yesterday, my vacuum cannot clean a selected room; it moves around aimlessly as it tries to locate itself, then gives up and starts making a new map. It will vacuum an area on the existing map if I use spot clean to select that area.
I also tried quick mapping and it won’t even load the second map long enough for me to pick a room, it just reverts back to the original map. What’s up? This is really annoying.
Mine started doing the exact same thing
Mine just started acting similarly. I select a room, but instead of going to that room, it just starts doing an area clean of the room its parked in. I’ve tried selecting different rooms, it seems to just ignore the fact that I selected any room or rooms.
