Vacation algorithm?
Does anyone know the algorithm used for the Wyze Bulb vacation mode?
Thanks
-John
Is this what you are looking for?
Support section on vacation mode:
Vacation Mode is a feature of the Wyze Bulb which allows you to set it to make it looks like you’re home without needing to go into the Wyze app to turn the bulb on and off manually. What it does is set the bulb to turn on and off automatically at random intervals between the times where you’re most likely to use your lights. This amounts to a no-muss, no-fuss solution to making it look like you’re home while you’re sipping an umbrella drink on the beach.
To turn on Vacation Mode:
  1. Open the Wyze app
  2. Tap your Wyze Bulb’s listing on the device list
  3. Tap the SettingsGear__1_.png icon in the top right
  4. Tap Vacation Mode
  5. Enable the ToggleOn.png toggle next to the Vacation Mode option
*Note - While this mode is active, it will remain on until you go back in and turn it off.
Some other things to keep in mind when using Vacation Mode:
  • Will only work between 6am-9am and from 6pm-11pm local time
  • Each bulb will be limited to being turned on for between 5 minutes all the way up to a full 60 minutes
  • Each bulb with Vacation Mode turned on will turn on at least once per hour
  • None of your bulbs will accumulate more than 8 hours of total ‘On’ time, with a minimum of 5 hours total of ‘On’ time during the full 9am-10pm period
