Is there a way to turn off motion tagging on the v3 like you can with the Pan v3?
Welcome to the Forum, @SeaMoore!
If I’m on the camera’s live view page and
- Tap the upper-right Settings
, then
- Tap Detection Settings, then
- I have a Motion Tagging feature on the Detection Settings screen.
Do you see a comparable setting, or is something missing? Let me know if a screenshot would be helpful.
Thank you very much. I just looked and it was right there, I missed because I was looking at one of my v3’s and thought I was logged into my 4V. Is there a way to turn it off on the v3?
You’re welcome! I don’t have any Cam v3s, but I found a relevant Support article:
To turn on Motion Tagging:
- In the Wyze app, tap Home, then your Wyze Cam.
- Tap More > Motion Tagging to toggle it on/off.
As you’ve probably already discovered, the Motion Tagging setting for Cam v4 is the same place as it is for Cam Pan v3
. My understanding is that Cam v3
uses a different UI, so I imagine that’s why that setting location is different.
Brilliant. Thank-you!
You’re welcome!
