I just replaced my Eufy pan camera with the Wyze Cam Pan V3 after the Eufy camera stopped tracking like the gears wore out. However, the Eufy cam allowed me to turn off the green tracking boxes and it was wonderful. As of yet Wyze doesn’t allow me to do this. Personally, I find the green tracking boxes more of a novelty than of any real use. It would be great to be able to remove them and just see the normal video. They’re kinda annoying and distracting. Please provide that option in an update. Thanks Wyze.
You can disable these in the cams settings > detection settings. It’s called motion tagging.
Already answered twice, but I agree, the Motion Tagging is about the first thing I turn off on a new camera. It’s cute for the first 30 seconds on your first Wyze camera. After that it’s just annoying.
About the only use for it is if you are getting motion events that you can’t figure out what is the trigger, turn on tagging to figure that out, then turn tagging back off.
Thank you everyone! I was assuming this would actually do away with motion tracking. I now see they’re two different functions.
I just checked the Android and iOS apps and the setting is still there. This is a Cam Pan v3 topic. If you are using a different cam type, the setting is located in a different location. What model of cam are you using and what is the app version number and firmware version number?
Then you have a Cam Pan v1 or v2.
I just replaced my older wyze pan cam v2 with the wyze pan cam v3 and can not get rid of the ugly GREEN BOX. I HATE THE GREEN BOX. I still want the canera to track movements but do not want to see a big ugly green box in my videos.
Scroll up, the procedure is shown above: Please allow users to remove the green tracking boxes on Cam Pan V3 - #3 by Seapup
The green box is only shown on Liveview but never recorded.
I forgot all about that setting. I did get used to seeing the green box.
Thanks.
OK, my mistake. The setting to remove the Green Box is under the camera detection settings called Motion Tagging. Turn off Motion Tadding and the Green Box goes away. Nice…
