I installed my first V3 yesterday and it works great. Problem is the it stopped recording events on my iPad at 11:00pm but continues to record on my iPhone?
Welcome to the forums! The app/device only records to your device when you hit the manual record button in whatever device you want to record into. Are you talking about the event tab, or in playback off of the live view screen? Cloud storage or local storage? Where are you looking at and where does it show no events after 11p? Are you using the same Wyze login on both devices?
Sounds like you enabled Event filters on your iPad around 11pm. If so, just clear all filters from your iPad and your events will show up. Wyze app Home > Events > tap the funnel icon upper right > Clear All > Show results.
