My V3 live feeds fine but does not record any events. All the setting are correct. Any ideas?
Did you tap the events icon at the bottom of the app on the home page. Are the filters on top of the events page turned on (Green) or off (White). Turn them off. Make sure you are on the correct day or tap cameras on the top right then show results. Do you have the cam set to continuous recording or events recording?
Thank you! That worked.
