V3 generating random static noise
I constantly have static out of my cameras that is so loud you can’t even make out the conversation people are having in the room. I just chalked it up to that’s how these cameras are built, with piss-poor microphones. I really wish they’d start improving the audio as much as they bother to improve the video.
This is exactly how i feel at this point! I previously had the CamV3 cameras and didn’t have this issue, but All 3 of these OG cameras have this issue, it’s so annoying!! I changed adapters and there was no difference at all, I’m done, i give up! I intend to buy at least 1 older model V3 and call it a day
I get the same noise on most of my cams
It would help if an AI filter could be added either in the firmware or in the iPhone Wyze app on a device model type basis. ???
Static …no lights… no connection… and the screw in the middlz bottom of base gets HOT. The housing is very warm as well … there is most definatly some kind of short involved… been down for some time this is the second v3 to bite the dust …i still have several v2 that have no issue even after years… switch out power supply if they stop working and they are right back to working… currently have a v2 with constant steady green light… cant connect…can not setup V3 s have not been awesome this isxthe second one to emitt noises and get hot while doing nothing got to be a short between speaker and power its mike a hot mic… not wind its power being delivered to the speaker directly something with this screw perhaps it is definately involved the temp of the screw is a little scary actually.
After last update ive had 3 cameras never come back on… 2 of these are v2 the other was a v1. i decided thay one was fried as there was no sign of life… after cord swaps outlet swaps using known working set from anpther camera …finally trashed it… then realized 2 more were never online never rebooting …and of those one had to be deleted and setup agian the other will do nothing but yellow light constant… can not setup …can not get it to repond at all anyone. Both v3 have just been surprises there was no update no bad weather… just come home and hear speaker static… and hot shell and never work again. V3s have some kind of issue with shorting … the tail cable is an issue inside maybe . You Cant remove the entire cable to replace it so who knows i may open it and see what is going on in there… please check your v3s for heat at the screw and housing … mine feels VERY HOT VERY QUICKLY
I’ve had no problem so far with cameras getting hot, green lights staying on or cameras basically dying, but the original static issue persist with every new camera that I’ve purchased and to be quite honest I’ve given up on solving it. At this point this is a manufacturer problem that they should’ve fixed immediately; this is not an end-user problem to fix.
Mine does same thing. For 3 years
Honestly I gave up trying to find a solution. I spent money on new adapters and that made no difference, and I invested time in other solutions that made no difference. I only began having the loud static noise once I “Upgraded” all my cameras to the OG’s. I guess perhaps this is a “you get what you pay for” type of issue, idk. Good luck to all living with this annoying issue.
Sorry to hear that. I have an OG but I don’t use the sound.
Maybe try adding a toroid coil to the cable?
I am sure you might find a smaller quantity. Maybe there is noise on the line?
How exactly would I apply something like that?
If you can find a filter made for thinner cords you just lay the cable inside the track, fold the other side over and snap into place. Often I have seen the cord looped to have two widths of the wire to be encapulated to hold it in place.
No guarantee but it might work. Maybe do some further research.
A new power adapter fixed my v3 camera with the exact same behavior you described!
