V3 Camera Trigger / Automation to Smart Plug or Blub?
Hi All,
I have a v3 with Cam Plus and I would like to set a ‘Trigger’ so that when a Person is detected, a room light comes on. Ideally I would like to use a Smart Plug but would a Wyze Blub also work - if so is it fairly easy to set up ?
Thanks
Really easy with either a Wyze plug or a Wyze bulb.
In automations, create a device trigger rule, using the “detect a person” trigger for that V3, then for the action either use “turn on/turn on for ##” for either the bulbs or plugs.
