When my V2 cam detects motion (and triggers a motion video,) I would like to simultaneously turn on a floodlight/alarm (or an appliance) which is plugged into a Wyze smart plug. How is this done? Do I require any other Wyze or other products other than the cam and the plug to implement this? Thanks. Frank
You can probably do this either within the Wyze app itself (3-dot menu from main screen, then Add/Edit Rules) or via IFTTT. For IFTTT, just use Wyze (Motion detected) as the Trigger and Wyze (Turn plug on) as the Action.
