Welcome to the Wyze User Community Forum @baxter129!
It probably isnāt working for your V3 cams because your cams are still on firmware prior to the fix - any version 4.36.9.xxx and prior.
The fix is ONLY in firmware versions 4.36.10.xxxx and newer which have NOT been made permanently available for full public release due to unrelated issues that have limited the release.
The only current release version available is 4.36.10.3406 which was pushed only to those on the 4.36.10.2864 release which had to be halted due to unrelated issues. It is being tested for stability and bugs now for those who updated to it. I suspect that it will be released for all V3 cams if it proves out as a stable release. If it doesnāt, I would expect another Beta round.
4.36.10.3406 is available for download and SD Card Manual Flash Update if you would like to join the testing effort. You can provide your testing feedback in the following thread:
Thanks for your info. Based on what you stated, I realized the camera I was checking didnāt have the recent update. However, upon checking other cameras that did receive the update, they arenāt working properly either. They show the correct storage amounts but there is no actual data to be found. Iāve added some screenshots for reference.
That very well may be the little blue bar fibbing to you because it didnāt update.
I see that the date you have selected is November 25.
I am also using 256GB cards and have no video prior to November 26th @ 10pm. That is the limit of the card when recording continuous in full HD. It will also never use the full capacity so that there is room for other functions that may need some space.
If you are recording in HD, your video may start a day or two later than what you have selected.
The real test is to pull the card, read it on a card reader, and see what the latest date folder, hour folder, and minute MP4 is on the card. That will tell you specifically how much time your card will hold when recording continuous.
I did more digging based on your comments, and Iām realizing that āthe little blue barā is a bunch of crap. Iāve found numerous places on ALL of my cameras where the appearance of āthe little blue barā or the lack there of had no bearing wether there was video recorded or not.
WOW!!! Rookie mistake with the email address. Because it was allowing me to respond right from my email, I had no clue it was being posted to the forum. I honestly thought we were having a one on one conversation.
Thanks for the heads up!
Regarding if this is a normal problem, I donāt know for sure. I would only āView Playbackā when needed. In those specific cases, I either found the āthingā I was looking for or determined it was outside the saved timeframe.
At least for the next few weeks, Iāll be checking my cameras at random to see if this is a reoccurring issue.
So I saw a while back that this was fixed and so I put new 256GB memory cards in my Wyze V.3 cams but I didnāt realize the firmware was needing to be updated manually. I read the thread about new firmware version 4.36.10.3406 but it looks like thatās not being rolled out to everyone yet⦠only people with specific firmware. Is that still accurate? All my cams have firmware version 4.36.9.139 and Iād rather not have to update the firmware manually due to my camās locations. From what I understand is that there are bugs in the latest firmware so they havenāt rolled it out to everyone yet? If they work out those bugs, will it be offered through the app to everyone on version 4.36.9.139?
The functionality concerns in question donāt seem to be affecting everyone. Mine all work fine, for example. But there were a percentage of people reporting an issue, so Wyze has suspended the public OTA update to the newer firmware until they can make sure itās resolved for everyone to have good functionality. There should be a new firmware update coming up that will hopefully be the solution.
In the meantime, like you saw, Wyze is allowing people to manually flash their V3ās to this firmware. If you do so, and you have any problems, you should probably just flash the firmware back to an earlier version again for now.
