I can no longer access my V3 Cam. It immediately crashes the Wyze app (V 2.23.16). I have power-cycled the camera; reinstalled the camera; factory reset/reinstalled the camera, all with negative results.
What happened???
What happened???
Are you running beta software? If so, load the production version from the App store.
That did the trick. Thanks. And a big bonus…that irritating floating arrow is gone too!
The V3 on iPhone problem with 2.23.16 was well documented here on the forum. A production release ( v2.23.23 ) fixed the bug - as you found out. Interestingly, Test Flight is still pushing 2.23.16…
The “floating arrow” is a setting that you control - but for the life of me, I could not find it. I know I turned it on not all that long ago so I could submit a log and then turned it back off - so it’s there somewhere ![]()
In the Beta App, the submit log button is controlled under App Settings. It isn’t in the prod version.
Gone now. That’s all tgg hi at matters. Hated that thing.
