V2 Purple Haze?
Getting weird purple haze on their v2’s? Not sure when it started. Seems to be in the left on all three of my v2’s.
Have read that it may be the IR filter, and that it can be replaced or fixed with a magnet, but can’t find any reference to HOW to do this.
Any pointers appreciated?
Try cycling through the Night Vision options: Under advanced settings in the Device Settings area, select Night Vision Mode and cycle from Off, On, Auto and then back to what you have set.
Normally if you see the Purple, it could mean the night vision mode did not fully disengage
