Yup Soddy, that’s the critter I use for card accessibility, but you would need the micro to sd card adapter to plug it into the PC
I HAVE the Micro to SD adapter so should be good to go. Will get to play in a day or so.
Thanks all.
Have you tried using TninyWebCam or Pro? You can use your Cloud login so you still receiving newest update and firmware. Lots of features.
There is also Agent which you can install the NVR and had lots of plugins for facial recognition as well as licences plate reading. These are the only two I have found that you don’t need to change the firmware off the live firmware. Plus you can add lots of extra features.
It’s tinyCam, tinyCam Pro.
You’ll need Pro, with the server running, to view on a browser.
It’s also Android only. I run tinyCam Pro Server on an Android TV box.
https://m.aliexpress.com/item/4001251710197.html
Form factor isn’t great, but technically, it might work.
Any tips of Kali Linux .Zsh? I have failed to get the file to play on VLC with x264 and x264 demauxers.
As well as the default Gnome player.
i need certain videos extracted in raw format to then copy and convert the copies of into mp4’s. Not about to send the whole MicroSD card in to be extracted by certain parties and have the oppertunity to submit what i choose as long as with those following guidelines.
