Is it possible to record with a Wyze Cam with mini disk installed but no internet access except an Android smart phone?
You need internet access (2.4GHz wifi) to initially set up the camera. After that, if you have a microSD card (what I think you’re calling “mini disk”), then the camera will record without wifi. To retrieve the video stored on the card, you will either need the camera to be back in wifi range, or remove the card and read it on a computer or your Android phone.
Great, Thanks RickO.
That really broadens the use of the camera. If you have an inverter in your car or truck you could use the Wyze Cam as a Mobile Cam.
Or instead of an inverter, something like this:
https://smile.amazon.com/gp/product/B00M6QODH2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
