Use painters tape to temporarily place wyze night lights
Use blue painters tape to temporarily place the night lights so you can test their sensitivity and how they should be linked with one another.
It makes for a clean install.
You can also use Command adhesive strips to attach the metal pieces to the wall if you already used the provided adhesive strips
