Does anyone know how I can get replacement Easy Pull Tape for the mounting of the night lights? I have to move a couple and can’t figure out where to get it.
You can use 3M command strips as replacements.
Thanks. Wasn’t sure it was that simple
I prefer these tabs, the Wyze versions are weaker and are prone to tear. I now only use the 3M tabs, and toss the Wyze tabs.
I had poor results getting my metal plates off the walls. The Wyze-provided release strips broke and pulled off paint while being pried, as a result. When I re-mounted them, I used 3M poster-size command strips. Plenty of “stick” for the job, and, in my experience, more likely to release as advertised when the time comes.
