Okay, maybe this is a crazy or stupid question but how do I save my LED strip lighting when I pull it off a wall or from behind my TV? What can I use to cover the adhesive part so that later I can reuse it?
You could really use anything that will stick to the tape, but not adhere the tape. I am sure foil, or plastic would work.
Mostly likely just roll it up onto itself.
The key for re-use would be to ensure the surfaces are clean from debris and dry.
There is a decent write up here in regards to reusing and cleaning
[Full Tutorial] Can You Reuse LED Lights?.
Thanks, I’ll check out the article.
