If there is a time that I don’t want to be recorded can I unplug Wyze camera and then plug it back in when ready? Do I have to do the setup process all over again? Was thinking about about getting a smart plug so I can turn it on and off as I see fit.
Yes, you can de-power it and not need to set it up from scratch again. If you think about it, that would be a REALLY poor design if you had to set up from scratch every time there was a power outage.
I have most of my cams plugged into a smart outlet today. Helps if I’m ever away and my cam won’t connect, I just power cycle it, and I’m good to go
