Triggers from garage door opener
My garage door controller sends me a notification when the door opens and when the door closes. But I can’t figure out how to use that notification in a rule to do something else - like turn on the garage lights.
What am I missing?
Accessories haven’t made it into most rule sets, but if you set a simple rule that says if the GDC camera sees motion, then turn on the garage light for x minutes. Then no matter if it is the door going up or down, or is you walking thru the garage, your light will come on.
You can do the same thing using a motion sensor as a trigger.
