Looking for advice. I thought I had it right, but no power to the unit. The furnace turns on, but still now power to the thermostat. image|375x500
Looks good. do you have a multimeter?
If so, check for at least 24v AC at the thermostat between the blue and red wires.
If not, check the fuse on the furnace.
Double Check by Following the thermostat wire to see if there is a junction (box) between furnace and Wyze.
Fuse is ok. Need to check voltage yet.
No junction box.
