Thermostat 220?
Anyone know if the thermostat will work with a 220 heater?
Welcome to the Wyze community @ral299!
If you’re able to remove your thermostat cover and take a look at your wires, put the used terminals into the compatibility checker. Make sure your power is off before removing the cover!
Wyze Thermostat Compatibility.
