"The Easy Switch ?" from the mesh to mesh pro?
I had a outdoor pan cam (ODPC V3) drop a connection . I hate climbing up n down, to reset / restart it.
Evem my basement, wyze cam (v2 blk), wyze bulb (V1), lamp socket & motion detector(V2), too, signals are weak (@ setup).
I don’t live in a mansion ( 3 bed, 1 bath, plus 3 more rooms).
So I bought the wyze mesh pro.
Can I set it up to match the old one. All done without , resetting all 30 devices ?
Thx !
As long as you use the same SSIDs and Password you should. However, not clear on what problem you are trying to solve. Didn’t you already have the Wyze Mesh router? Is it a matter of WiFi signal coverage or???
It wasn’t a probken at first, but now it is.
Mesh V1 vs Mesh Pro, has to be better ?
(3 walls 20-30 ft, in a 1960 era home)
Nothing new or with a radio signal in between them, too.
Thx !
You need to simplify your setup based on this post:
Try to eliminate everything EXCEPT the ISP router/modem and your Wyze Mesh Routers. Don’t connect anything directly to the ISP gear EXCEPT the Wyze master router. You have way too many complications in your setup to diagnose things.
