Temperature sensor selected for C, but display on favorite screen in F,
On the new Wyze iOS app, the temperature sensor displays in degrees F, even though the device has been selected to use degrees C.
I have the same issue. Did you find a solution?
No solution, no reply from Wyze on whether anyone noticed my post.
It is so obvious just pointing it out to Wyze should have got it fixed.
There’s been several app updates since I pointed this out, but not fixed.
Some issue occurs in another couple of spots where the app does not follow the units preference. I’ve lived in both Metric and old units countries so am able to do the translation in my mind, but it it still irritating.
I understand, I’m french and I live in Quebec. For me the conversion is not really easy.
I just made a new post for this issue and for another issue regarding the IOS widget that only displays battery level and not temperature…
Thanks for your answer…
Have a good day
I have the same issue, all my temp sensors appear correct in the device list but show Fahrenheit in the favorites pined up list.
Has this been fixed? super annoying, small change in the code should fix it
I have same issue
I can’t believe this is still an issue. The global standard for temperature can’t be used on the home screen?
