Climate sensor widget IOS batt level displayed instead of Temp
Hello,
I have 2 issues with the climate sensors:
  • Even if the sensor is set to display the temperature in Celsius, I’m only able to read the temperature in C when I enter in the sensor detail, but in the overview the sensor remain in F.
  • The IOS Widget only display the battery level of the sensor, but not the temperature.
I have same issue regarding temperature setting but battery status show normal even though I am receiving constant notifications that the battery is low. Honestly I dont think the battery status reporting works, I believe it is there for looks and no functionality. I have 3 sensors and all three doing same thing.
