See quite a few questions on this… Is Wyze working on something? Has anyone used a third party sensor with any luck? Thx All.
I use the sensors that come from Ecobee. Temp is very accurate but the occupancy part of the sensor leaves a lot to be desired.
Thank you for the guidance - I will check them out. If you had a part number or model, that would also be extremely helpful if they have multiple types…
These appear to only work in conjunction with an Ecobee thermostat.
However I have also heard good things about these:
Govee Wireless Thermometer Hygrometer, Mini Bluetooth Humidity and Temperature Sensor with Data Export for iOS Android, Temp Humidity Monitor with Alert for House Wine Cigar Living Room Baby Room Amazon.com
I have been using an Ambient Weather WS-0262A for several years. It’s meant for outdoor use, but I have the outdoor sensor in the basement. I bought it because it is IFTTT compatible.
I mainly use it to turn the dehumidifier on and off with a smart socket based on the moisture level, but occasionally I will ask Alexa what the indoor temperature is at the base unit.
Now that i have a smart thermostat, it’s easier to ask Alexa for the temperature with it.
I use the Switchbot temperature/humidity sensors (although only temperature is available when queried via Alexa or Google Assistant). The sensors are $19 each on Amazon (and have a display), but require a hub for use with a voice assistant or over the internet. (Their Hub Mini is $39).
The sensors:
https://www.amazon.com/gp/product/B07L4QNZVF
Thanks! Will take a look…
