Is there any way to mounting it without being able for a stranger to steal it or knock it down ?thanks
You can look through the mounting threads in the wyzecam forum for some ideas… You will see that some are putting a screw through the base. But realistically it’s made out of plastic. As most low cost cameras are. It’s not made for high security applications. A child could break it off the mount.
If you need that sort of security and want to use this camera- You’d probably be best off looking at housings that are stronger and more tamper resistant to place the camera inside. Or, think about mounting them out of reach, or a location that will capture the person on the 12 seconds of cloud video before they can tamper with it.
