Suggestion feedback
I would really appreciate is a simpler and more effective way to detect movement. When one camera picks up a certain movement, I’d like the other cameras to automatically start recording as well.
Additionally, it would be great to integrate AI that can detect specific movements and then use photo comparison to track that same object across all cameras.
I also suggest adding a “pet tracker” feature. This would allow users to upload photos of their pets, enabling the cameras to recognize and monitor them more effectively. It would also make tracking movement across multiple cameras easier.
Overall, if the program could be recoded so all cameras work together seamlessly, instead of operating individually, it would greatly improve the system. This would make everything 100% better!
[Mod Note: Post moved to new topic for better visibility]
Also 100 times more expensive :rofl:
Welcome to the Forum, @abimaelcaraballo! :wave:
I believe your post was moved to try to get you some better visibility for points you raised, because it didn’t really fit the topic where you commented. A number of remarks you made seem to be current Wishlist requests, such as these:
Please familiarize yourself with How to Use the Wishlist and visit relevant topics to click or tap the Vote button above the initial post in a Wishlist request that you support and share your ideas and use cases in the comments!
Some things you suggested can already be done, like this:
Using Automations in the app, you can have motion detection from one camera trigger recordings and cloud uploads of videos from other cameras, which seems to align with what you’re suggesting. Also, the ability to record locally is a feature that I believe many Wyze users enjoy. With a sufficiently-sized microSD card in each camera, you can have have them all recording continuously and access your recording history going back several days. For instance, with one camera I’ve seen the history go back to ~17 days with a 256 GB card.
I’m not quite sure what you mean by this:
I wonder if what you’re suggesting is like the Multi-Camera Timeline View they introduced last year. If you’re talking about some other kind of feature where cameras somehow coordinate in concert with something like AI-enhanced detections tracking across a multiple-camera field of view, then I think I’ve seen suggestions and discussions of that sort of thing here in the Forum, as well, and you can seek those out using the Forum’s search feature!
I hope this helps. Thank you for sharing your ideas, and please let us know if you have questions!
