Suggested Feature
I would like to see the ability to turn off the night vision LEDs. This would allow users to place the camera behind a window at night without glare while still using night vision but making use of external night vision lights placed outside the home.
+1!
Thanks for the feedback! I’ll make sure the Devs see it.
Thanks!
It would be a useful feature for special situations.
Loki has mentioned a few times that this is in beta. They are working on it. Post to the roadmap is below. You can read up on it there. Hope this helps. :grinning:
How about a ‘dark’ color scheme for the app? I’m finding under some circumstances that the light green/blue-ish text on a white background is difficult to see (or the entire display is way too bright) and being able to have a dark background would bring out the text better. Just make it a switchable option in the app e.g. Light / Dark background, any dark earth-tone color would be fine.
Hey @susurus there is actually a current topic for this. make sure to vote at the top so the Dev’s seeit :sunglasses:
here you go sir. check it out
