I’d like to see a quick run option in the app. When adjusting sprinklers or making repairs it needs to have the ability to turn on one circuit for a few minutes without creating a new schedule .
Welcome to the Wyze community @jfancher53!
The Wyze sprinkler controller does have a quick run feature.
To start a Quick Run:
- In the Wyze app, tap on your Wyze Sprinkler.
- Tap on the water icon.
- Select the zone(s) you want to water and how long you want to water them for.
- Tap Save .
If you have a different idea for a testing mode for the sprinkler controller, you should add it to the Wishlist if t hasn’t already been added.
A little quirky at first. All had a 10 minute default time. I figured that out, now smooth sailing. Thanks.
jf
