When the controller moves from zone to zone, it seems to power off the pump momentarily, causing the pump start relay to clunk OFF clunk ON with each zone change. Which is not a terrible problem but it should just leave the power on continuously when multiple zones are programmed to run one after another… or am I setting something up wrong?
I’ve noticed the same issue - between zones, the pump shuts off momentarily. Prior controllers I’ve used leave pump running between zones. Seems like this would cause a lot of wear on the pump. I don’t believe there is anything we (customer) can change.
Ideally, the pump would run for the entire sprinkler time, and as it progressed through zones, each zone valve would open just before prior one closes. This would keep the water flowing through the pump.
This appears to have been fixed. I do not know which update, but the sprinkler pump no longer shuts off between zones - it stays running, like the prior controller did. Thank you Wyze!
Can you guys share some of your installation system and equipment? I have to install irrigation and grass from zero and would like some tips and info about equipment and installation. I have an already done Well with nice clean water. But that’s it. I am told I need a pump relay between the device and the pump? Please can any of you help?
I have a shallow well pump that is 240 volt. The pump relay goes between the sprinkler controller (low voltage) and the pump (high voltage). It is like a switch to turn the 240v on. This link describes it better:
When the sprinkler controller goes to turn the valves on, it turns the pump on first via the relay.
I just installed mine and it does the same thing between each zone switch the pump gets turned on and off very quickly, but it is very noticeable. I am on the latest firmware.
I didn’t think this was the case when we installed ours in Summer 2024, but I’m definitely noticing brief relay drops in between zones. You’d think that eliminating this would only take a really simple change in firmware.
