Can not turn on spotlight. How exactly do I set it?Also, I was told it has an audible alarm when an intruder approaches, not only is your now being recorded.
Hi rob4uandme, if you have the Floodlight V2, go to [Settings] - [Floodlight Settings] and customize the floodlight as needed.
The Motion Warning feature will audibly prompt intruders that they are being recorded. You can go to [Settings] - [Detection Settings] and turn it on. Camera sensitivity and PIR setting can also be adjusted under this tab. Hopefully it helps.
